5 kw Sunsynk Inverter specs for max wattage solar panels.
Hi, I have the 5 kw unit and the supplied documentation indicates that it can handle 6500w panel input @>11amp and less than 480V. Why are there so many different wattage input values for the 5kw unit on the market, How do i know this is correct for this model? I am planning on installing 10 of 325 watt, 9 amp and 41 Volt panels in series per MPPT. Am i pushing the limits here or play it safe and only install 5.2 kw?
stabilitycore
Jan 14, 2021
6.2kw! Impressive. That make my ROI seem so much better. I am planning on feeding back into the grid. I have an almost constant 1.5 kwh draw during the day (fishtanks and pool pump) as well as 2 geysers that I will need to change to 2kw elements at a later stage when the batteries are added. We currently use approximately 1100 to 1250 units a month so all info to get the most out of these components is really appreciated.
