Public·407 members
CanBus cable between two 50kW inverters in parallel
Has anyone found a solution to the cable being limited to 2 metres long
Dec 11, 2024
Where did you get the 2m length limit ?
Having said that, normally you would have the battery as close as possible to the inverter which means the CanBus cable would be quite short.
