Work Mode Selection
Hi,
I have a Sun Synk 5Kw battery which has been fitted recently and some solar panel fitted 10 years ago which are not interconnected.
I have a night time tariff to fill the battery up during the night.
Obviously I'd like to draw as little as possible from the grid during the day especially on sunny days without exporting either.
What is the best Work Mode between the following and what do they mean?
Under Equipment tab / Setting / System Mode I can select between the following:
  • Selling First (That's one that I will avoid)
  • Zero-Export + Limit to load only (Currently Selected but unsure about the meaning)
  • Limited to Home (Unsure of what this does)
Thanks in advance
Fabrice
jacekowski
Oct 24, 2023
voltage will rise towards Voc, adjusted for cell temperature, but you don't need much load for the voltage to be a lot closer to Vmp. 6 panels, even with 50V-ish Voc are not going to be an issue.
