Public·385 members
PV generation max out at 3800w
Sunsynk 12kw hibrid 3 phase inverter
12 x 550w JA solar panels
10.65kw sunsynk battery
Loads in excess of 9,5kw
The grid tied sma 6kw inverter produces 4,9kw, with 5,8kw panels installed on the same roof.
The 12 panels is split 6 x 6. 2xmppt, As you can see out of the graph, it only generates approximately 8 A per string in total 3800 W maximum. It must be at least 5,400w
There must be something wrong........ any suggestions please
john.t.jones
Oct 07, 2023
I had the same problem - it was being clipped to 3.8Kw. Turns out it was a software bug. After a firmware upgrade it allowed over 3.8Kw and when SOC got to 100% it limited the PV input to the inverter to 3.8Kw
