Public·324 members
PV export to non-essentials
We run an 8kW hybrid with 2 x 172Ah BSL LiFePO4 units. The CT is supposedly installed after the prepaid meter to allow for PV export to my non-essentials (geyser and oven). I tested this on a sunny day a few days ago, by unchecking "Limit to load only" on the System Mode settings. I then had some strange behaviour: It seemed that the excess PV indeed powered my home (essentials as well as non-essentials). However, the "Load" reading on my logger went to 0 and remained there. This can be seen in the screenshot below of the system:
One can see that I unchecked the "Limit to Load" around 14h00 to allow the PV to feed the system. Note that there was no loadshedding (AC was available). At 16h40 I checked "Limit to Load again", as it seemed as if the Load was then fully supplied by the Grid, even thoough I have a timer that should use the battery. When I checked "Limit to Load", you can see the battery is used to supply the Load, which could be measured again. Below is a zoom of the plot above.
Is this an issue with my CT? One thing I can mention is that the distance between my inverter and CT is quite long and I saw on some other info online that a long CT cable may be an issue?
Any insights or comments would be appreciated.
Thomas Francis
Jun 12, 2023
Thanks, Leon. Will confirm CT port connections with the installer and reconfigure settings.
