Question regarding battery discharge behaviour once full
Hello.
Just a question out of interest.
I have an 8KW Sunsynk inverter with 2 x 5.32 KWh batteries. Everything is working fine.
The sun comes up and the batteries charge nicely. Once they get to fully charged via PV, the charging stops and I then see the below behaviour (circled in red)
My question is : Is this just the battery discharging from 100 % to 98-97 %. ?
I would have expected a slow constant draw to 98/97 %, not the "chatter" graph above. (ie on batt off batt on bat off batt)
I can see the batteries status leds changing to indicate charging/supplying/charging/supplying
The chatter stops after a while when the SOC drops a bit.
This is during a time where the load is low and there is plenty of PV.
Not hassled about it, just checking in to see if others see the same.
It seems to be a constant very low draw - between like 5w and 25w.
Yeah, Sunsynk Battery.
