Public·406 members
DNO inverter size
I purchased an 8k inverter a couple months ago and now after Dno application thet say "6kW is the maximum inverter generation you can have on this connection and you have to limit the export load down to 1kW using G100 export limitation scheme"
Can I limit my 8kw inverter to act as a 6kw to satisfy the Dno?
David Berry
Jul 18, 2024
I don't understand the generation limit being stipulated? As far as I was aware the DNO can only stipulate the export. But you can set the max sell power in the settings menu in the work mode settings. I believe all DNOs have to allow 3.6kW export in the UK so something seems odd.
