Waking up a Lithium battery using AGM stetting
Hi,
I have a system with Sunsynk BYD Lithium that appear to be at 0%. I have been told by Charles that if I change the battery type to AGM I can get some power into the Lithium to "wake" them up. However, he did not give me the settings and I have tried this and nothing is happening. Can anyone help?
Many thanks,
Andy
From a post on the FB group, measure battery voltage, enable AGM V, set the minimum AGM voltage below the measured voltage and it should start charging.
