Public·327 members
Parallel inverter slave battery settings
I've got 2 8kw inverters in parallel with batterys controlled with seplos bms. Everything works fine and communications to the master inverter reads out data on the lithium section on the inverter display. The slave inverter shows 0 for everthing on the info screen. I'm not sure what to set the slave inverters battey settings to. The same as the master (currently set like this) e.g tick lithium with rs485/can comms or something else given its only the master that communicates with the bms/battery? Alternatively should it be set to no battery? Does anyone else have a parallel setup they could share their slave setting with me? I can't find anything in the rescources about this. Thanks
Anthony Envisage
Jun 15, 2023
Yes Groots, I understand that. But you have to have the battery section of the slave inverter set to something. Either no battery, lithium, Agm etc. Or does it not matter what you set the battery parameters to on the slave as it is irrelevant?
