Public·382 members
Max Grid Charging rate
I am looking at purchasing a Sunsynk Sun 8KW ECCO Hybrid Inverter and a 30kwh battery with no solar.
I can get cheap ev Tariff for 5hrs and would need to be able to charge the battery in this window.
Will the 8KW ECCO Hybrid Inverter charge the battery at 8kw just from the grid alone (fully charging the battery in less than 4hrs) or does anyone know what the max charging rate is from this inverter from the grid alone.
Thanks in advance
lvrasmoklet
10.7.2024
As @Groots said, in theory, there is no problem trying to do what you want ito the inverters being able to push 190A charging current.,
With the individual batteries in the stack running a 125A breaker though, let's hope that the inverter's control of the BMSs will somehow ALWAYS ensure that no more than the rated 100A per battery pack of the 190A will flow........... even with a sick or unbalanced individual battery pack in the stack.
I know some people apparently view my comment as over the top, but I would still recommend asking the particular question in detail given here from the supplier.
Better to be sure BEFORE you spend the money
