Public·326 members
More than 8 batteries
Hi Technical, I would like to know if there is a firmware upgrade on the 12KW 3p inverter that allows you to connect more than 8 lithium batteries? If not what is the workaround?
maarten
Nov 23, 2022
Tx, the issue is if I connect more than 8 batteries the master goes into error mode, and this is if i use the 3000c as master and end with a 2000, maybe i must try and end with a 3000c and see if its better.
