How to determine actuator compatibility across brands and models
I ran into the same problem a while back, and using the Actuator compatibility guide https://www.progressiveautomations.ca/pages/replacement-chart made things way easier. It helps you match specs like stroke length, load capacity, and voltage across multiple brands, so you can find a replacement that fits without modifying mounts or wiring. I measured my old actuators, checked the guide, and picked a compatible model that worked seamlessly. Definitely saves time and headaches.
Unknown member
Dec 21, 2025
It’s really useful to have a reference when dealing with components from different brands, especially with actuators where small differences in stroke or load can affect performance. Taking the time to carefully compare specs before buying ensures that systems run smoothly, reduces trial and error, and can prevent damage to other connected parts. It’s a small step that saves a lot of stress and keeps projects on track.
