Public·385 members
Info on Sunsynk 5kw inverter
Good morning
I need some advice about this situation.
I have a Sunsynk 5kw Inverter and 5kw battery at the beginning of this year.
My CT clamp is on my main feed and I can only see the power my Inverter uses, my load and grid are the same. I don't have my geyser and stove on the Inverter, but I can not see on my Inverter (grid feed in) when my geyser is on or off. It doesn't show the usage of the stove and geyser. Is there maybe a setting? Because my CT clamp is the right way around with the arrow pointing to the Inverter.
I bought it in April 2023
I did upgrade it in May 2023
botha.christiaanj
2023년 10월 10일
Try untick "Load only" at system settings. Your geyser/non essentials will get PV power as well. Unfortunately when it is cloudy geyser/non essentials will drain battery if PV is to little.
