Public·391 members
Master /Slave option for single inverter
hi, I had my install yesterday of a single 5kw inverter 7kw of panels and 10kw battery.
I noticed in the settings my inverter is set to Slave by the installer.
is that correct, if there are no other inverter attached shouldn't it be Master?
what difference will it make to the operation?
thanks in advance
D.A
D.A
Feb 11, 2023
I spoke to the installers, they said slave is the default so it's left at that. master will only matter of you have multiple inverters.
didn't say anything bad would happen if it's set to master though, but I'll leave it as
