Drawing power from the grid while charging battery
The battery seems to be gettng charded from the solar panels while the house load is supplied fromthe grid. In this scenario I want the house load to be supplied by the solar panels and any surplus enegy to go into the battery. I want minimal power to be drawn from the grid,.
Any idea what I need to look at?
Thanks,
Stephen.
Assuming your firmware is up to date..
Watch out for the data on the app vs on the inverter pannel. The app is a snapshop every 5 minutes, it may have only drawn 300w for a fraction of a second while the inverter caught up with a change in demand but that is when the data was captured.
If it is consitantly doing it when to check the inverter then there is likely a setting somewhere overriding the System Mode.
Sometimes if there is a problem with the battery it will force a charge from the grid fix an error.
There are also tarrif specific settings and other conditional charging settings elsewhere in the app.
I believe you can now ask support in the web app to review and optimise your settings (they have some defaults they can push out based on your setup) not tried it myself though.
