2 inverters with the app??
how does the app work when you have 2 inverters on the same firmware? one is a 4k feed in tariff setup the other is a 3k battery setup
CF_UK
Jul 03, 2023
If they're linked and setup in parallel then you just add both inverters to one plant.
If they're not linked and in parallel then you just have 2 plants with 1 inverter in each.
