Public·324 members
Low KVA Genrator, ultra low tickover load
Hi, watched your generator video where you said not possible to use low KVA generator as the load would kill it. I understand. However, where the tick over load is below 200 (160-190) watts for the house, surely in this instance there is enough left to charge the batteries. Fully off grid system with plenty of panels but Welsh mountain weather. Intended to connect generator to Grid port and use Gen/Aux port for dump load. Generator is manual (pull start) and would be used should winter bring 5 days of black skies as desperation move.
