Herman Roesch
Herman Roesch
Sunsynk Inverter and Narada Batteries
I have two 4.8KW Narada lithium batteries and a Goodwe 5kw Inverter, I want to replace my Goodwe Inverter to an 8kw Sunsynk Hybrid inverter and I was wondering if my Narada batteries will work and be compatible with the Sunsynk Inverter. Is it a setting change I will have to do? Or will Narada batteries just not work?
Any advice would be appreciated.
14 feb 2024
The following Narada batteries are compatible.
You will have to make a custom cable to connect the batteries to the inverter. You will also need to connect the 2 batteries together using the RS485 ports
