Public·406 members
Battery not reaching 100%
Good morning, i have noticed over the last few days that my 5.5 ECCO doesnt seem to be charging my Seplos 280L battery to full charge overnight. I am using the micro inverter input to harvest my solar from an existing PV installation (installed under FiT) and for the first few days it did seem to be working well, including charging overnight to full capacity (14.3kw). i did have the software update installed a couple of days ago, but im sure that the issue started before then.
please see attached photos to check my settings to see if the issue is with my programming ? if my programme settings are ok then it could potentially be my battery, from what i have seen on youtube with off grid garage it might be an issue with my battery bms not resetting to 100%?
Oct 22, 2023
AS you have been following the Off-Gride Garage, you will have watch Andy talk about the Seplos BMS V2. He make it quite clear thatthe BMS will not reset to 100% SOC unless you have a cell or battery pack over voltage alarm. Have you checked the setting on the Seplos BMS or are you using the defaults settings?
