Public·371 members
BMS to Dyness battery
IEverthying has been working fine. However, it now appears that the although I adjust and can set timings (setting grid charge times and discharge times) on the invertor or via remote access, these instruction is not communicating to the battery. As a result the battery is charging when I dont it to charge as its then diverting the PV generation to battery and not load. I know some aspect of the BMS is working as when I set the timer to grid charge at night (cheaper rates) then the battery does fully charge between the set times. However discharge is now completely beyond my control as is the day time PV charging.
