Public·397 members
Sunsynk settings Parameters,
Hi there please could you help with some settings on the Sunsynk 5kw hybrid parity inverter,
1. On the Grid parameters if I set it to LD load first & zero export then will it prioritize charging the battery and then feed available power to the home once the battery is charged ?
2, On the same page if i set the grid charge to only charge at times in the evening then will the battery only charge during these times? I just want confirmation it will work this way I realise its a self answering question :)
Appreciate your answers
