Public·330 members
Max Solar Power
The Max Solar Power setting in Advanced is showing 3800 but the 12 x 405w panels installed should generate 4.86kw. What should this field be set to and if it’s currently incorrect, how will it have been affecting system performance?
Peter Myring
15 thg 5, 2022
‘Machine’? The field name is ‘Max Solar Power’! I had assumed that this was the max power of the panel installation which is 4.86 kw. The inverter is the Sunsynk 3.68kw ac 7kw hybrid. Still confused as to what this field should be set to….!
