New installation in an RV with 24v system
HHi, I have been looking at the mini beast
3.6kW Ecco
Hybrid Inverter
SYNK-3.6K-SG04LP1
Can you set this up to run with existing 24v lithium batteries and what would be the maximum charge rate. Also, would this work with 1000w solar array. The batteries have their own built in BMS but no communication cable to connect to the inverter. They would be set up via the battery monitor already installed which can communicate with the inverter.
I like the idea of an all in one system but can't find anyone who has used this set up.
Hope you can help.
Jul 18, 2023
I hope you have a SUN-3K-SG04LP1- 24-EU as the SUN-3K-SG04LP1-EU is a 48V inverter :-)
WRT the 1000W solar array, as long as the Voc is more than 150V (Startup voltage is 125V) it should work.
