Parallel Lifelynk Inverters
I am about to install a small lifelynk S inverter with a single mppt input it will be connected to a already installed 2.4Kw/h solar panel array and will be looking to install another identical inverter in parallel to increase the current and battery storage.
The question is to double the current of the inverters connected in parallel do i need to connect another solar panel array to the slave inverter mppt MC4 sockets to achieve this? or is this all done via the battery to battery cable/communication connections?
Generally to be ale to get double the power (make use of the second inverter) you will need to add a separate solar panel array to the inverter.
However, what is the specific model of the Lifelynk S inverter you have?
