Public·272 members
CT Coil Positioning
My Sunsynk 8KW inverter is on order. It will be used in off-grid mode but will use a grid connection for charging batteries. The inverter will be in a shed 80m from house with a buried cable from the grid consumer unit in the garage for this purpose. Is it ok to use the CT coil on the grid cable coming into the inverter at the shed end. Is the CT coil necessary in this scenario. Thanks
Michael
Gareth Seymour
Gareth Seymour
Apr 03, 2022
You will be hindering yourself if you ever wanted to install solar and use export solar limit to net zero
  • Rokil Naro
    Rokil Naro
  • Арно Дориан
    Арно Дориан
