Public·384 members
Can you bond the neutral and earth together on the out put of the 8kW sunsynk inverter.
Halcyon
21 sept. 2020
Yes you should if you are running fully Offgrid. If you are running the inverter as a hybrid connected to mains then do not permanently bond the earth neutral. You should use the relay control functionality to bond earth and neutral only when Offgrid (island mode) and un bond when grid returns.
