export settings
we have 2 3.6kwh sunsynk inverters, 1 is for the 4k feed in tariff which works fine, the other is a 3.6kwh sunsynk inverter with 4.4k solar and a 20kwh batteries, when the batteries are soc 100% the inverter drops the export to less than 1kwh even though both were running above 3kw due to the fine weather we have been having, if i use some power in the house say the hot tub the inverter shoots back up to above 3k... Question is what setting is stopping me exporting the full amount?... also could the ct coil be detecting the export from the other inverter?? thanks
