Public·326 members
Smart Switches...
With home integration being so wide spread, and having seen sunsynk dip thier toe into the intelligent connection world, are Sunsynk or could Sunsynk look at smart switch intergration.
I would like for example, be able to turn on a remote fan that is connected to a smart switch (TP Link) to cool the area where the inverter is installed when the inverter itself reaches a certain temperature.
this is just one example but as you have shown with the Phillips Light bulbs, this can be done.
Kind regards
Chris
Unknown member
Aug 03, 2023
The easiest way to do this would be to have say sonoff temperature sensor and smart switch connected to day ventilation fan. I was planning to do this but having monitored the temperature, it peaks to
65 C on AC side
70 C on DC side as reported by inverter irrespective of how ventilated it is.
Battery is reported 25-28C though is on the floor and if it gets colder I might stick some insulation under
Leaving it as is for now
