Can bus battery Comms Sunsynk Max to Fogstar (Pace BMS)
Anyone help me on the cable pin outs for Sunsynk Max to Fogstar battery rack system? The Max came with a standard ethernet cable, not quite long enough, so I made one a metre longer. But looking into pin outs there seem to be loads of different requirements for different batteries and inverters. I have found something about the Deye using 1 to 1 pin layout in standard t568b format, is this correct for Sunsynk to Pace BMS in the Fogstar? The manual seems to suggest a different cable pin out to the cable supplied, and some smaller inverters from Sunsynk have a BMS and an inverter end. Thanks!
David Berry
Sep 23, 2023
A t568b ethernet configuration worked perfectly, which is odd as the pinot is not as in the Sunsynk manual!
