Data download
Hi, is there anyway to download data from Sunsynk app as csv file? I am not using Solarman app.
The Sunsynk website will be temporarily unavailable from Tuesday 5th May due to scheduled updates as we transition to an upgraded online platform.
Customer Support UK: +44 151 832 4300 | SA: +27 (0)10 1003589 | NL: +34 40 798 7136
Alternatively email support@sunsynk.com or get in touch via the Sunsynk Connect app.
Hi - AFAIK (I am open to correction) not from the app, but from the web interface on www.sunsynk.net, you should be able to select "Operation Data" from the sidebar on the left. If you enter your inverter Serial Number (visible under "Equipment...Inverter") and select a date (doesn't look as if you can select a range), you should see "Download" at the top right.
