Public·392 members
50kW with 143 kWh battery
Planning a large battery installation for a factory and looking for opinions.
The battery will be either 10 parallel 48v 14kWh battery packs mated to 4 12kW inverters in master/slave set up with common D.C. bus bar or 1 500v 140 kWh battery mated to 50 kW inverter.
Batteries will all be able to communicate with the sunsynk inverters over CAN.
Any thoughts on pros and cons of each approach?
markcoomer07
markcoomer07
Nov 15, 2022
Straight off the mark i would say 4 x 12KW.At least if one inverter is faulty you wont be totaly down.If you have one inverter and it go down you will be down untill it is repaired or replaced.
Regards
