Public·394 members
Max Discharge current
Hi Everyone,
I have 3 B100 Revov batteries upgraded from 2. One of the batteries is of the older type and I am unable to use the Lithium setting as the 2 newer ones do, so the Inverter is set to AGM.
Sunsynk 8.8Kw Inverter
Battery Capacity 300Ah
Max Discharge current 185A it is supposed to be 250A and unable to go beyond 185A
Max discharge current
185 A
Max charge current
120 A
Max grid charge current
40 A
Max generator charge current
40 A
Battery float charge voltage
54.5 V
Battery absorption charge voltage
55.5 V
Battery equalization charge voltage
55.5 V
Should I be worried at all?
Budgie Burgess
22 feb 2025
OK! Thank You very much. That clarifies it then.
