(micro) inverter on gen port for off grid?
Is it possible to couple an existing PV inverter to a Sunsynk system? With the important sidenote that I would also like the existing PV inverter to work in off grid mode.
While testing this, the PV inverter shutdown when the AC grid was turned off.
Is there an internal Sunsynk diagram that explains this?
Edit to original post:
After experimenting more it actually works absolutely fine. There is just a somewhat large delay for the PV inverter to start operating again.
Best regards,
It did! (Test setup) I think it was also charging the battery, what is your situation?
