Gareth Roberts
Gareth Roberts
Sunsynk Ecco w. Batteries - Solar charging from separate inverter
Hello,
Installed and have working a 3.6kw Sunsynk Ecco inverter with Pylontech batteries. All working good.
I also have a solar system, but in a different part of the property, connected via a different inverter.
When the solar generation is more than my load the house starts exporting to the grid, the connected Sunsynk CT shows this. Is it possible to set up the Sunsynk inverter to use this excess power to charge the batteries rather than export the powe? Its not at the moment. The solar inverter is far away so re-wring the solar DC cables to the Sunsynk inverter is a really complicated job. However I could fit a second CT and connect to the Sunsynk inverter if it helps.
Happy to provide more detail on my settings etc if it helps.
Thank you
Gareth
Membre inconnu
10 déc. 2023
All,
Thank you for your help! All set up and working.
Took a bit of time in this lovely UK weather to get enough solar power to be able to charge the battery, but eventually got there!
Thanks all
Gareth
