Public·382 members
500 kWh energy storage with Sunsynk
Hi,
I am currious if it would be possible to make a 500 kWh system with Sunsynk inverters
Most batteries I found can only do 16 or 32 in parallel making a total maximum system capacity of +/- 160 kWh which can be connected to a master Sunsynk inverter
The preferred option I would like to find is a battery system that can be paralleled more, smilair to the LV hub from pylontech but then with the 160 kWh systems. The master Sunsynk inverter would then communicate with the total battery bank.
If there truly is not a battery system that can be connected in parallel would it make sense to have multiple master inverters where each inverter has its own battery bank?
The concern I have with this situation is that the inverters do not work together, thus in zero export to CT one inverter might do all the work to supply the load while the other inverter and batteries do nothing because the load is already compensated by another master system (no even load spreading)
Curious to hear any thoughts
Best regards,
