Public·391 members
Islanding and g99
For a sunsynk 5.5kw ecco inverter, but probably the same for all sunsynk's.
What's the difference between g98/99 and general standard grid mode for these inverters?
cliff.harker
cliff.harker
May 08, 2023
I think if you pick g98/99 all the other options below seem to get disabled. So I think all it does is set those values correctly. So if your installer set then all correctly manually, it probably doesn't change anything at all
