Inverter not charging conform time settings in system mode
Hi,
My Sunsynk 5.5 is connected to 2 Pylontech US5000 batteries. The inverter charges the batteries not like it is told so to do in the system mode time settings.
In the setting it is said not to charge at 0.00 hrs (by setting the power to 0), but it charges at the maximum allowed amps that is set on the battery settings page.
At 12.00 hrs it should charge at 1500W, but it is charging at maximum again.
The discharging is done conform the time settings with the correct power.
What should I do to let the inverter charge conform the time settings? What am I missing?
Thanks in advance, Marc
Hi, On your 3rd screen, the Power column is for Discharge only. This does NOT change the charging rate. To set the Grid Charging rate - change the value on screen 2 (currently set to 70A) This does not affect anything else.
Also I would untick 'Activate' on the first screen.
btw, times are fine starting and finishing at 0:00.
