How to setup only one phase of a three phase DB with an inverter
Hi There
I have a client with a three phase supply to the main house on a farm, the DB contains a main breaker for three phases and is distributed to different loads in the house (one phase is plugs and lights[L1], one phase is stove and geyser [L2] and one phase is not used [L3]). only one phase[L1] (plugs and lights) needs to be connected to an inverter for backup power.
Is this possible to do with the Sunsynk 5Kw inverter? can you use only the Neutral and the L1 as supply to the inverter. Is a neutral bridge required as well?
Regards
Stephan
