8KW inverter 1 to 2 amp drain from grid
I have an 8KW sunsynk inverter just installed. I observed that during the day with full Sun and more then sufficient power available from the PV panels I am still pulling about 1 to 2 Amps from the grid.
I am using the timers on the program change and discharge to control battery SOC
Zero export
Priority Batt.
setting Grid trickle feed from 20W to 0 Watt does not affect this 1 to 2 Amp drain on the grid.
What can be the cause of this grid drain.
Thanking you in advance for your response
Andre
Jul 19, 2023
Apologies - forgot the video link - https://www.youtube.com/watch?v=i6IN_NLxPqc
