Public·399 members
Welding with a Sunsynk inverter
Can I run a 200A Tig welder off a 16KVA Sunsynk inverter?
stuart
Apr 04, 2025
Welders run at quite low voltage, so 200A is probably only about 3-4kW max. A bit close to a 13A plug limit! I've done stick welding set to about 100A powered by a 2kW petrol generator, which struggled sometimes and tripped on a long run, but did work. So I'd have thought your inverter would power it easily.
