CT wired up correctly but nit working
Hi guys
i have my CT connected on my 8kw inverter on 5 & 6 white on 5 black on 6. I am measuring 30mV and it changes depending on the load but its showing 0watts on the inverter display.
its about 3m from the inverter on the live wire arrow pointing towards the inverter.
What could be the problem?
Have you solved this problem? My issue is that regardless of which direction i put the CT, the reading is always negative. So it always appears as if i am pushing power back into the grid.
