Hi guys I have 3x 8KW parallel 3phase setup with a pylontech bank of batteries.
Parallel Comms and phases set Correct. Master battery is connected to one of the master Inverters. The batt is communicating with the one Inverter and details are showing on that inverter li ion page. However it is not showing on the other inverters Li ion page. Is this normal ?
The issue I am having is solar feeds loads and charges batts during the day and then discharges from batts to load at night even though AC power is available.
In system settings under SOC/V it only allows me to only input voltages.
what should the system settings be - if we want solar to feed loads and charge batts and at night feed loads with ac and keep batts charged until and event of power failure.
thanks in advanced
Hi yes thanks for replying. I find that if I choose lithium battery in battery type settings, under system mode the Soc/V Column only shows voltages and not batt percentages. ?
