Parallel or NOT to Parallel
I am considering un paralleling my 2 inverters, I am not getting the expected output on my West array - Slave Inverter, I feel it is being dragged down by the East - Master Inverter, towards the end of the day the 20kW of CATL batteries are 80% +, the input into the East Inverter is sub 500W and the West is in full sun fluctuating from 1850 - 2750kW dependant on AC demand (Load was 120kW - 60kW each). I think the DC imbalance cannot be compensated for and therefore drags the West Array down - clipping
Is there a problem with running the East & West inverters as 2 individual (separate) grid connected inverters? I want to test the theory that allowing the West Array / Inverter to run unshackled from the master (East Inverter) will prove my point, I can then pass this data over to Sunsynk for analysis for adjustments to the algorithm?
Today in dawn to dusk sun, East array produced 45kW the West array 30kW they are only 10 degree east of South at 32 degree incline.
Thanks for any feedback, in anticipation
Try doubling up to see what happens?
