I am a little puzzled as to vhy the range offered is 5-75A and you have set the value to 185. This could be an app issue, but if not I am not sure how this will impact the performance. If it is using the 185A value the system should be able to support approx 10kW of load.
Certianly 3*5.12kWh batteries should be able to deliver the enough power for this inverter.
Can you share a Generation Daily graph so I can see how the inverter is working?
