50kW as Grid-Tied
I need to use a 50kW in a Grid-Tied setup. There is already an 85kVA Diesel generator in the system.
If the SunSynk is connected after the Generator Change-over switch, can the C.T.s be used to ensure the "Trickle Feed" figure will make sure the generator does not get power shoved back to it ? ( in a similar manner that this is used in normal hybrid setups. This system will not have a battery.
Thanks, Charles
