540w panles on 5kw sunsync Inverter
Hi All
As the post above suggests I would like to know if i can onstall 540w panels on a 5kw inverter.
I have to do an east/west installation and only have space for max 7 panels each side of my house.
Thanks in advance.
Yes, it will be fine. The inverter will limit the current to just under 13A. If it exceeds the current significantly, you just end up wasting more power. The voltage is the thing that makes the smoke come out.
