Public·391 members
Sunsynk Slave does not report grid import/export.
I have 2xSunsynk setup as master and slave. Only one CT coil connected to the master. I import and export to the grid but only the master inverter contributes to this value at plant level. Lookin at each inverter individually I can see that both show Grid Power and CT External L1 metrics, but only the master inverter accummulates the Grid Import, and Grid Export values. The slave inverter Import and Export stays at Zero.
The nett effect of this is that my total import/exort for the plan is about half of what it should be.
If this is logged somewhere else I would be more than happy to read through that thread, I have just not found it.
I have logged this as a bug but unfortunately have movement on it.
I appreciate your help.
Master Inverter:
Slave inverter:
Charl Le Roux
Charl Le Roux
Nov 16, 2023
This is definately a software issue. My Solar-assistant reports the grid import and export correctly, sunsynk ap not. I have a ticket open for a few months, no movement on it
