Public·394 members
New 5.3 batteries fault
Hi, when I have connected 2 of the new 5.3 batteries with the built in breakers together I keep getting an alarm on them both. They work independentley fine but when they are connected together with the data cable they alarm out. All the cables are in the correct ports. Is there a start up procedure for these new batteries? The only start up procedure I can find on line is for the older batteries where you press and hold the on button for 3 seconds. The new batteries dont have the press on button, they have a toggle switch.
shj.yorkshire
Feb 15, 2024
I didn't turn the breaker on after the toggle, always before
