Public·385 members
Rackmount Inverters
I have had a look at the datasheet and manual for the rackmount inverters and I am having trouble finding some key information.
Firstly the manual talks about having 500mm of space on either side of the inverter, which doesn't really make sense for this sort of inverter so I'm guessing that's just a copy and paste from the other manuals? What are the clearance and ventilation requirements for this inverter? Can it go in an enclosed panel with a ventilated door for example? Does the are flow from front to back with the fans running?
Second, what are the dimensions of the inverter, perhaps im blind but i couldnt find this on thr datasheet. L, W,H? And how far does it stick out of the rack? One image I found shows the rackears are mounted fairly far back on the inverter so it would stick out quite far.
Basically I just want to known if I will be able to mount two of these in a 19" panel and could I have the back or the side of the panel against a wall?
