Public·326 members
colin finch
colin finch
Not charging battery
Hi had 5.6inverter and 5.6 battery installed i think i changed settings on app have chatbox sunsynk but still same solar comes in to inverter and exports but does not charge battery unless i put on grid charge some of settings seems bit vague and confusing grid charged yesterday too 100 % then left it discharged but this morning its on 15% and sun has come out it exported to grid but not battery also about 1 -6 overnight all settings on app go to zero then startup again at 6 ive checked wifi had new sky hub put in but still the same surely should tell you what you getting off grid between these times
Colin
pete
Apr 23, 2025
Suggest you have a read here and see if it becomes clearer when you compare your settings https://support.sunsynk.com/support/solutions/articles/103000244987-understanding-timer-settings
